14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Why does all of a 3D linked model show
105 Posts No Rating |
I linked a 3D AutoCAD model into Reivit. In the plans and isometrics the imported model shows the cut line, what is beyond and hides what ids beyond a floor or wall, but in the building sections if the section touchs any part of the imported model it shows the whole thing regardless of if it behind or beyond the cut and it ignores walls. I'm assuming that this is related but it will show as a solid in the fllor and isometrics but in the building sections it will only show as line regardless of the visablity settings. How do I get this imported 3D AutoCAd model to react in the building sections the same way it reacts in the plans and isometrics?
import the cad model into a generic model in place family. different categories react differently to section cuts
Run that by me one more time with a little more detail. I am still newish to Revit and need a little more explination. Thanks for using your time to help.
in your project go to component and click the drop down arrow, select Model In-Place, select an appropriate category for your autocad model and link in your dwg file. i suggest you do this starting with the casework category and once you finish it check to see if you get the desired result. then edit the in-place family and change the category several times so you get an idea of how different categories look in section cut.
Got it. I will give that a try - thanks for expanding.
That worked great!! Thank you very much.
linked model does not show up in 3D |
Thu, Sep 11, 2008 at 2:47:35 PM
Linked Model Showing In 3D View Only |
Tue, Aug 5, 2014 at 1:11:42 PM
Lineweights in linked model |
Wed, Nov 19, 2014 at 8:06:44 AM
Linked Model - Losing only some doors from linked model |
Thu, Oct 21, 2010 at 1:52:14 PM
Linked Walls Show Hatch |
Fri, Jan 9, 2015 at 9:50:15 AM
