8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Copy/Monitor Topographical Element
45 Posts No Rating |
Hi All,
We are colaborating on a project where the structural engineers have modelled the existing landscape as a topography. I need to ammend this to reflect the proposed landscape but I can't seem to select this element under the copy/monitor tools. Is this correct that this can't be done?
Thanks
Simon
Yes, you cannot copy / monitor topo elements.
Copy / monitor is limited to only a few element types.
Not sure why it is limited to those few itmes. Personally, I wish you could copy monitor any item.
Open the file and edit it or get the structural people to do so.
Cheers for reply, I opened their file seperatly in the end and copied and pasted it back in, was a bit of a fiddle getting in back into the right place though, I couldnt find a copy by base point type tool for going between different files?
Copy/Monitor walls |
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue |
Fri, Nov 6, 2015 at 2:16:27 PM
Copy/Monitor Deleted Element Revit 2011 |
Sun, Aug 14, 2011 at 6:09:41 PM
Copy Monitor Grids |
Tue, Feb 3, 2015 at 8:20:16 AM
Can't Get Copy Monitor to Work for Grids and Levels |
Fri, Feb 21, 2014 at 4:55:28 PM
