Forums >> Revit Building >> Technical Support >> Mass Floors not all showing up - some missing
Tue, Apr 10, 2012 at 10:32:16 PM | Mass Floors not all showing up - some missing
cadboi08
Hi,
Using Revit Architecture 2011, I've model a few In-place masses and tried to Mass Floors for Levels G, 1-6. For some reason it's only creating the Mass Floors for Levels G and 1, nothing from 2-6, despite them all being ticked on.
The mass is a gradually sloping one, ramping and steping up from Level G up to Level 6 - not sure if this is causing the problem?
I've checked the VG overrides and masses/mass floors are on. I've checked hidden elements. I'm not using worksets or anything - it's a pretty simple file (some design options were used, but all this stuff should be in the main model).
Cheers
Check out RevitTube for Awesome Revit Videos Daily - https://www.youtube.com/channel/UCl-rjEtxDTE0DOrtqOV8aKw
Wed, Apr 11, 2012 at 4:44:46 AM | Mass Floors not all showing up - some missing
cadboi08
After a full days work they somehow reappeared. . . after making some changes to one of the voids in the mass. No idea why/what happened - but still interested to know if others have experienced mass floors missing.
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
Mass Floors with a Minimum Height/Clearance
Wed, Apr 18, 2012 at 5:25:50 AM
trimming mass floors revit 2011
Sat, Apr 23, 2011 at 5:53:00 AM
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
Problem with a floor slab with Mass
Fri, Apr 25, 2014 at 12:38:46 PM
Page generation time: 0.3190
