Forums >> Revit Building >> Technical Support >> How do I undo the double click to edit a family in 2013
Mon, Apr 9, 2012 at 4:17:20 PM | How do I undo the double click to edit a family in 2013
aaronkennedy
This is annoying.  If I click twice on somthing like a text note too quickly it automatically opens the family of whatever it is that I clicked on.  Please tell me there is a way to turn this off!
Aaron
Tue, Apr 10, 2012 at 7:13:36 AM | How do I undo the double click to edit a family in 2013
You must not be clicking on a simple text note.  Instead, you must be clicking on material notes or similar.  I don't think you want to turn this off and I hve never seen where you can.
Wed, Apr 11, 2012 at 9:02:11 AM | How do I undo the double click to edit a family in 2013
aaronkennedy
Well it seems to be all the families, furniture, plumbing, doors, NOT text notes, but tags.  Just annoying and slightly inconvenient. Especially when I need to go through and change a lot of room names or door tags.
Wed, Apr 11, 2012 at 9:21:00 AM | How do I undo the double click to edit a family in 2013
Sorry  I see you are on 2013  - I miss read that the first time.  Yes, this is a new feature in 2013 and I had not seen this earlier.  I can not find a way to disable this "feature?".
Wed, Apr 11, 2012 at 9:21:59 AM | How do I undo the double click to edit a family in 2013
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I really like the new double click feature to open a family. There is a sufficient difference between a click . . . . pause . . . . , click and a double click for me. The old click . . . pause . . . . . click has not changed at all from what I can tell. I have been double clicking families to edit them for 3 releases. My 2 cents.
Wed, Apr 11, 2012 at 10:29:33 AM | How do I undo the double click to edit a family in 2013
aaronkennedy
Thanks guys, we jumped from 2011 to 2013.  I never noticed it on '11. Oh well.  Thanks for the help.  I am sure I will learn to work with it.
AAron
Wed, Jul 4, 2012 at 5:55:38 PM | How do I undo the double click to edit a family in 2013
raja15
In regards to this matter, I was wondering if it's possible to ASSIGN a double-click to Activating a View in Revit 2012? Similar to how you would apply a keyboard shortcut for the process.
As far as I have seen I can't find anywhere that says it's possible, just wondering if someone knows a bit more about it?
Thanks in advance.
Mon, Mar 4, 2013 at 1:45:53 PM | How do I undo the double click to edit a family in 2013
cfrb00
This is the most annoying feature in Revit 2013, looks like there is no way to disable it either. Can anyone tell how i can participate in beta programs? there is so much that still needs improvement in revit
Mon, Mar 4, 2013 at 9:13:12 PM | How do I undo the double click to edit a family in 2013
CDWdavid
5 Stars: 5 Votes
Hi Aaron,
This might not be a Revit's issue.
Try to change your mouse "Double click" speed through windows "control panel". I adjusted to the level that I feel most suitable speed for my way of clicking.
Tue, Mar 5, 2013 at 6:25:13 AM | How do I undo the double click to edit a family in 2013
coreed
coreed Avatar
4 Stars: 16 Votes
This is a new 2013 feature. Far as I know it cannot be turned off and there has been many complaints.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Sep 17, 2013 at 11:42:17 AM | How do I undo the double click to edit a family in 2013
#11
aaronkennedy
Somehow I missed CDWDavids post.  That worked because I normally double click pretty fast.  I also got used to the click pause click.
Tue, Sep 17, 2013 at 1:05:11 PM | How do I undo the double click to edit a family in 2013
#12
TKennedy
4 Stars: 8 Votes
It's a 'feature' in 2013 that cannot be disabled. I also learned to slow my click speed (annoying), but it's something that should have been optional. Fortunately, in 2014 it is optional. They also added a bunch of other double-click options, which is great.
Tue, Sep 17, 2013 at 1:22:01 PM | How do I undo the double click to edit a family in 2013
#13
aaronkennedy
They already have 2014 out?  Good grief.
Tue, Sep 17, 2013 at 1:37:47 PM | How do I undo the double click to edit a family in 2013
#14
Where have you been aaron?  2014 has been out for several months and there is even an update 1.  Get off of 2013 - it's a bad release.
Tue, Sep 17, 2013 at 1:38:14 PM | How do I undo the double click to edit a family in 2013
#15
TKennedy
4 Stars: 8 Votes
Yes, and it has a bunch of awesome new improvements.
Double Click to edit Floor / Roof / Stairs
Thu, Jul 4, 2019 at 4:35:29 PM
Family won't retain changes made in Edit Family mode
Tue, Feb 25, 2014 at 4:10:40 PM
How do I undo a split surface of my topo?
Thu, Oct 8, 2015 at 6:53:44 AM
How to Undo parts
Mon, Feb 1, 2016 at 5:45:02 PM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Page generation time: 3.1608
