Forums >> Revit Building >> Technical Support >> stairway problem
Mon, Apr 9, 2012 at 2:10:37 PM | stairway problem
dak4482
Hi,
Im trying to create a set of steps that rises to two different doors 90 degrees apart. In other words the steps rap around the edge and you can enter a doorway going north and the other one going east. the steps going to each door are on equal levels. Any help would be greatly appreciated. Ive looked L-shaped and U-shaped and they dont seem to apply.
Dan
Mon, Apr 9, 2012 at 2:49:55 PM | stairway problem
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Could you attach a picture to help explain a little more?
Mon, Apr 9, 2012 at 3:21:52 PM | stairway problem
In 2012 and earlier, if this is a 'T' set of stairs, it will have to be two stairs.  Here is what is available in 2013:
http://wikihelp.autodesk.com/Revit/enu/community/videos/2013_Revit_Videos/Creating_a_Custom_Stair
Wed, Apr 11, 2012 at 10:23:20 AM | stairway problem
sroreilly
WWHUB: Wow. Like that!
Updated Stairway to Heaven
Sun, Nov 15, 2020 at 7:43:33 AM
cut plane for stairway representation
Mon, Aug 14, 2006 at 6:02:35 PM
Problem with revit family (attic stairway)
Sun, Aug 31, 2014 at 1:03:43 PM
Modify Elevation of Railing
Tue, Feb 2, 2016 at 6:54:38 PM
railing with glass or solid
Tue, Mar 4, 2008 at 12:50:02 PM
Page generation time: 1.4429
