Forums >> Revit Building >> Technical Support >> Section cuts
Mon, Apr 9, 2012 at 1:07:17 AM | Section cuts
agall51
Trying to poche the section cut that I have made.  Using (VG) I filled in my walls, ceilings, floors, etc with a poche and all is left is my topography and it doesnt seem to work.  Is there a way I coud do this?  I have been trying to create a filter or something that could layer over the topography like you can do in Illustrator but I have found that is working.
Mon, Apr 9, 2012 at 7:17:07 AM | Section cuts
The poche for the site in section views is controlled from the massing & site and modle site pulldown.  There you can set the poche pattern and the elevation of the poche base.
For Elevation of poche base, enter a value to control the depth of the cross-section of earth, for example, –30 feet or –25 meters. This value controls the poche depth for all topography elements in your project.
Section cuts WAAY too deep!
Tue, Jun 7, 2011 at 5:34:55 AM
Rouge sections cuts
Wed, May 2, 2012 at 4:07:32 PM
Multiple Section Cuts as duplicates
Thu, Dec 4, 2008 at 11:44:59 AM
Detail Cuts
Wed, May 3, 2006 at 5:03:48 PM
Phases and Section Cuts
Thu, Mar 19, 2009 at 9:49:27 AM
Page generation time: 0.2023
