Forums >> Community >> Newbies >> Invisible windows after render
Fri, Apr 6, 2012 at 5:51:42 AM | Invisible windows after render
Lolflakes
When I use the render-function. It does not show my windows. they are 'invisible'. I am using Curtain Wall as window in the bottom.
How do I solve the problem?
(sry for bad english)
Fri, Apr 6, 2012 at 6:50:55 AM | Invisible windows after render
4 Stars: 205 Votes
Try changing the color and the Reflectivity parameter
Fri, Apr 6, 2012 at 6:55:43 AM | Invisible windows after render
Lolflakes
In the settings of the curtain wall?
Fri, Apr 6, 2012 at 7:03:04 AM | Invisible windows after render
In the settings for the material that is assigned to your curtain wall components.
Fri, Apr 6, 2012 at 7:18:50 AM | WWHub
Lolflakes
Quoting WWHub from 2012-04-06 07:03:04
Sorry I cant find it. :S
1. I click on the curtain wall
2. In the properties-window I click on "Edit Type"?
3. Then? I dont find anythin about reflection or the color
Is that correct?
Fri, Apr 6, 2012 at 7:29:02 AM | Invisible windows after render
4 Stars: 205 Votes
Select the PANEL of that CW, goto properties, edit type, materials...... see the image attached
Fri, Apr 6, 2012 at 7:31:58 AM | Invisible windows after render
No, that is not correct.  The curtain wall is made up of componenets.  Usually mullions and panels.  You can crete a CW with multiple mullion types (or no mullions at all) and multiple panel types.  The materials are assigned to these components individually.
So goto your elevation view and tab select to pick which components you are using for mullions and panels.  NOTE - these are type based componets and settings.  Goto the components properties setting and change the material there.  This will change all compontes of this type.
Fri, Apr 6, 2012 at 8:13:38 AM | Typhoon
Lolflakes
Quoting Typhoon from 2012-04-06 07:29:02
There is no "material" when clicked on Edit Type. I have no "Material and Finishes" tab. My tabes are:
Construction, Vertical grid Pattern, Horizontal grid pattern, Vertical mullions, Horizontal mullions and identy data
Edited on: Fri, Apr 6, 2012 at 8:14:03 AM
Fri, Apr 6, 2012 at 8:19:10 AM | Invisible windows after render
You are selecting the curtain wall - that is not what Ty said to select.  Follow the selection process I posted then follow Ty's instructions.
Fri, Apr 6, 2012 at 8:24:33 AM | Invisible windows after render
Lolflakes
Here is a video that shows how it looks like
http://www.youtube.com/watch?v=L0XOtYdYe_M
Fri, Apr 6, 2012 at 8:53:12 AM | Invisible windows after render
4 Stars: 205 Votes
And here you have like I told you before: http://screencast.com/t/VhELqJtar0NI
Fri, Apr 6, 2012 at 9:06:45 AM | Invisible windows after render
Lolflakes,
Look at the properties of the CW you posted.  NOTE that you have nothing assigned for panels or mullions.  You have "Empty System Panel" You have nothing but the definition of the limits of your CW - no panels no mullions - nothing!
You really need to spend some time with your Help :  Curtain Wall Workflow  << That topic and the included topics under it.  Or at a minimum, watch an on-line video on curtain walls.
Rendering an invisible wall.
Sun, Apr 24, 2011 at 12:01:49 PM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:45 PM
Windows are not transparent
Mon, Apr 13, 2009 at 7:43:00 PM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
WINDOWS
Sat, Dec 23, 2006 at 9:19:14 AM
Page generation time: 0.3033
