Forums >> General Discussion >> Revit Project Management >> Wall and floor connection/cut
Thu, Apr 5, 2012 at 6:10:07 AM | Wall and floor connection/cut
serialkill
I am working with revit for a long time and recently an issue appeared. I was working with mass, then attached walls by face, divided mass into floors, made them. In a section view my wall is with angle to background. I want to connect wall to floor so that none of the floor would be visible outside. I add an image. I was trying to work with cut profile, but it doesn't eliminate all of the problem. I use revit 2012.
Thank you in advance.
Tue, May 8, 2012 at 3:29:22 PM | Wall and floor connection/cut
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Go to that level on your floor plan, click on the floor and edit the boundry to follow your wall profile
Tue, May 8, 2012 at 3:38:33 PM | Wall and floor connection/cut
The boundry edit will not work.  You need to use either an in-place void set to cut your slab or pull your slab back and use a slab edge sweep that has the profile needed to match that wall angle.
Tue, May 8, 2012 at 3:43:26 PM | Wall and floor connection/cut
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would add the floors manually to avoid the use of voids and sweeps.. seems like a lot of extra work.
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
wall floor connection
Mon, Nov 9, 2009 at 1:45:05 PM
floor to wall connection detail
Mon, Jan 25, 2010 at 3:04:31 PM
Cut floor around walls
Fri, May 24, 2013 at 12:09:36 PM
Stair riser at floor connection
Tue, Jul 31, 2007 at 11:51:27 AM
Page generation time: 1.1353
