Forums >> General Discussion >> Revit Project Management >> Arch Template Size
Wed, Apr 4, 2012 at 4:25:36 PM | Arch Template Size
rhecht5000
Hey all,
How big is your template file and what size projects do you do?
We typically do TI work in the 3 - 6000 sf range and our template is 50mb.  Seems big.
Wed, Apr 4, 2012 at 10:41:53 PM | Arch Template Size
revitape
revitape Avatar
4.5 Stars: 9 Votes
Wow. That seems massive. I have 2 templates, one with all masterformat materials and one without and they are both around 10 mb.
Do you have a ton of families preloaded in the file or any hidden dwg files stuck in there somewhere? Those are the two major file size culprits I can think of off the top of my head.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Thu, Apr 5, 2012 at 10:41:24 AM | Arch Template Size
rhecht5000
Yeah, we have a bunch of families.  We have a pretty streamlined production system so the cost of that is lots of stuff already in the file with the benefit being less time actually working in the file.  But, I'm doing a project with a lot of exterior work and lots of rendered materials for the clients benefit and my whole file is only 79mb.  So, when I saw our new template was 50 for predeminantly interior work, it set me back a bit.  We're still figuring it out.  Thanks for your response.
Fri, Apr 6, 2012 at 6:52:41 AM | Arch Template Size
Our template is 13.8.  If your loaded families are used on EVERY project then that is OK.  If not, then I don't believethey belong in the template.
As revitape asked but maybe not deep enough, do you have a lot of included CAD files?  That includes CAD details in both detail elements and drafting details that are pre-loaded.  If you have those, you should plan on getting rid of those as soon as possible.  Clean them up and make them Revit components.
Arch. Template setup
Sun, Nov 7, 2010 at 9:45:25 PM
sheets pre set in template
Tue, Apr 10, 2007 at 11:36:32 AM
Arch wall in Strucural Template not visable in 3D view
Thu, Dec 15, 2016 at 10:17:04 AM
LEGENDS IN TEMPLATE FILE?
Thu, Aug 14, 2008 at 3:58:33 PM
Revit Template Setup Information
Wed, Aug 20, 2008 at 2:20:47 AM
Page generation time: 0.3602
