Forums >> General Discussion >> Revit Project Management >> Revit 2012 Truss System (framing members not showing)
Wed, Apr 4, 2012 at 3:48:53 PM | Revit 2012 Truss System (framing members not showing)
kelava
I have been batteling with this all day.
I have designed a truss system. Loaded the framing family for the truss.
Loaded it into the project. Made sure that loaded framing members are selected for structural members of the truss.
However on the project all I can see are the cables of the truss. No structural members.
The truss looks fine, except it is just lines, no steel structure that was applied to it.
What could be the issue here?
Tue, May 8, 2012 at 3:22:51 PM | Revit 2012 Truss System (framing members not showing)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Try setting your detail level to Fine
Tue, May 8, 2012 at 3:27:58 PM | Revit 2012 Truss System (framing members not showing)
Are you set right in VG?  Show all categories check box then set structural categories to show correctly - not analytical.
Wed, May 9, 2012 at 8:16:02 AM | Revit 2012 Truss System (framing members not showing)
kelava
Thank you all... I figured it out
teafoe5 was right
stupid simple... but when you don't see it, you don't see it Smile
Wed, May 9, 2012 at 9:25:33 AM | Revit 2012 Truss System (framing members not showing)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
More often than not it seems like its the simple things that seem to stump us!
Beam system members invisible in all views
Fri, Mar 25, 2022 at 5:50:55 AM
Hip roof overbuild framing
Thu, Apr 16, 2009 at 10:42:51 PM
Truss Visibility Toggle
Thu, Jan 17, 2013 at 12:30:50 PM
Object rotates when copied
Fri, Mar 7, 2014 at 2:25:15 PM
Cutting Structural Framing Members with other members in Revit 2012
Tue, Jan 31, 2012 at 10:54:50 PM
Page generation time: 4.1029
