Forums >> Revit Building >> Technical Support >> Applying Multiple materials to the same family
Tue, Apr 3, 2012 at 3:55:09 PM | Applying Multiple materials to the same family
jbias1
I'm not sure if there is already a thread out there for this so sorry if one exists (I tried looking...) I am new to modeling custom objects in Revit since everything I'm reading suggests not bringing in objects from Sketchup (and I've had problems in the past from doing this) and I have finally created my first model which is a table and I converted it into a display case since I can't seem to find a model similar to what I need.
Heres the problem, with both familys when I try to add a material to just one object (the table top for example) it changes the legs to that material as well and same for my display case. How do I tell Revit to distinguish from the different elements and make them sepereate. Right now my entire display case is either glass or metal which for obvious reasons just doesnt work.  I tried selecthing one part at a time and it still assigns all the parts the same materials. I also tried adding material parameters to distinguish between them but all that does is change the name, and still applys the same matieral to the whole model. With my table I was able to select the top and make it wood, but once I attempted to add something to the legs it changed the whole model. Right now I have the wood top and legs with nothing assigned to them.
Wed, Apr 4, 2012 at 4:30:47 AM | Applying Multiple materials to the same family
4 Stars: 205 Votes
Check your family, you have the same material name to the top and the legs, edit your family, select the legs and create a new material parameter, then do the same to the top.
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:09 AM
replacing materials in multiple family files?
Wed, May 6, 2009 at 7:13:40 AM
Applying materials to new families
Mon, Jun 19, 2017 at 10:28:03 AM
applying multiple hatch to wall
Wed, Jan 2, 2013 at 5:35:10 AM
applying revit materials into imported sketchup file in revit family
Sat, Dec 10, 2011 at 6:52:34 AM
Page generation time: 3.6933
