Forums >> Revit Building >> Technical Support >> Worksets in halftone?
Fri, Mar 30, 2012 at 12:36:30 PM | Worksets in halftone?
AVig
Background.... We have an apartment complex with multiple units. We've set the unit layouts up on their own workset and set the corridor and demising walls to the main workset. Is there any way to get the unit workset to print out in a halftone on some of the plans when we're just annotating main wall layouts?
Fri, Mar 30, 2012 at 1:03:21 PM | Worksets in halftone?
In the VG window - add a filter for that workset.
Fri, Mar 30, 2012 at 1:40:28 PM | Worksets in halftone?
AVig
Thanks got it. Haven't used filters much in the past.
Wed, Apr 11, 2012 at 2:51:08 PM | Worksets in halftone?
AVig
Follow-up. Everything is working great except we have a few instances where we have used Model lines and they don't seem to respond to the change to halftone in a filter. Any workaround for this?
Wed, Apr 11, 2012 at 3:07:35 PM | Worksets in halftone?
Were the model lines in the correct workset?
Wed, Apr 11, 2012 at 3:14:25 PM | Worksets in halftone?
AVig
Yes but they are not associated with a family. We're using them for irregular angled shelf lines and other weird corner conditions.
Wed, Apr 11, 2012 at 3:28:40 PM | Worksets in halftone?
Why work so hard on solving this small issue here?  Just over-ride graphics in view by element and half-tone it there.
Halftone worksets in a linked file
Thu, May 16, 2013 at 5:40:50 PM
Design Options Halftone?
Tue, Nov 20, 2018 at 10:58:56 PM
Revit MEP 2012 - Halftone not Working...
Fri, Oct 5, 2012 at 12:47:21 PM
halftone hatch/fill pattern?
Wed, Jan 16, 2008 at 10:14:12 AM
Halftone cut Patterns
Mon, Nov 19, 2012 at 4:05:25 PM
Page generation time: 0.9898
