21 Users Online (19 Members):
Forums >> Community >> Newbies >> No light inside building
15 Posts No Rating |
When I use the render-function the interior-pics are completley dark because there is no light except some from the window. How do I get light inside buildings?
Too many possibilities. Please read similar threads and search the forums. Then if you still have problems - give us enough information to help you. Pay attention to :
- Your light - does it really work?
- Is your light above the ceiling and there is no holes
- Is your light surround by a material that is not transparent
- Is your light turned on (and the sun off) and pay attention to intensity.
Read the treads and pay attention to them based on the above.
Have you put lights inside your building would probably be a good place to start also.
"Have you put lights inside your building would probably be a good place to start also."
How do I do that?
You need to insert a lighting component into your ceiling. Click the "component" button and load a light fixture. Check out your help as WWHub stated to get a more detail about componets. There are also a lot of good tutorials that revit has for beginners, I recommend going through them.
Light source inside the light fixture |
Fri, Feb 22, 2013 at 7:24:32 AM
Light Source in Revit - the dead horse |
Thu, May 6, 2021 at 4:34:17 PM
13
need HELP with creating a light shelf! |
Thu, Apr 19, 2007 at 7:15:59 AM
Tubular Skylight / Light Projection / Building Construction |
Thu, Nov 6, 2014 at 8:28:07 AM
Downlight with hidden light source |
Sat, Nov 23, 2013 at 8:19:33 AM
