Forums >> Revit Building >> Technical Support >> Phase Filter
Wed, Mar 28, 2012 at 4:13:57 PM | Phase Filter
bert
Hello!
I noticed we had a problem with phase filters and was able to narrow it down to this:
The Setup:
I have a model with two phases: Phase 1 and Phase 2.
On each phase, I've created a new element.
I now link this model into another model with the same phases set up.
I've confirmed that the phases between host model and linked model are mapped correctly.
When I switch a view from one phase to the other, I'm seeing the expected change in content.
The Issue:
If I create a new phase filter OR rename an existing default phase filter, and apply that phase filter to the view, changing the view's phase setting has no effect on the contents of the view. For instance, whether my view is set to Phase 1 or Phase 2, I'm seeing contents from both phases.
Here's the kicker, If I rename the phase filter back to it's original name, everything works fine again.
My real issue:
I had really deleted all default phase filters and created my own, so naming them back is not really an option (I tried).
Anybody have a clue on how to resolve this?
Thanks in advance!
Edited on: Wed, Mar 28, 2012 at 4:17:16 PM
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Thu, Mar 29, 2012 at 7:54:11 AM | Phase Filter
bert
issue resolved: http://www.revitforum.org/architecture-general-revit-questions/7452-phase-filter.html
Both Link and Host should have the same phase filters set up.
using RAC-2013
Filter by Phase
Thu, Apr 15, 2010 at 10:37:34 AM
R-17 Wanting to change the phase filter setting in a Walk Through......
Tue, Jan 3, 2017 at 11:07:39 AM
Filtering a phase that you have created
Tue, Dec 5, 2006 at 8:34:41 PM
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
New opening cut showing in Existing elevation with [show complete] filter
Fri, Sep 12, 2014 at 4:21:24 AM
Page generation time: 0.4603
