Forums >> Revit Building >> Technical Support >> Elevations
Tue, Mar 27, 2012 at 3:34:27 AM | Elevations
CarlaRafferty
Once I select my 'East' and 'South' on the 'Elevations' 'Properties Menu' it shows up an Cross Section instead of a side profile. How can I change this?
Tue, Mar 27, 2012 at 5:03:20 AM | Elevations
4 Stars: 205 Votes
Go to a plan view, select by crossing your elevation symbol and move it away from the building.
Tue, Mar 27, 2012 at 9:35:20 AM | Elevations
LIZARD2806
3.5 Stars: 7 Votes
Just clarifying Typhoon's comment in case you are a new user....when you select the elevation symbol in plan, a blue line will appear which indicates the view plane of the elevation.  Click and drag this away from the building.  It is most likely going through your model right now, which creates a section.
**Using Revit Architecture 2009, 2011, and 2012**
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
how to add elevations to door & window schedules
Tue, Oct 30, 2007 at 11:59:24 AM
Getting door elevations
Thu, Nov 21, 2013 at 6:12:08 PM
12
Editing Font on titleblocks below elevations/plans on sheets?
Tue, May 22, 2007 at 4:46:36 PM
interior elevations
Sat, May 2, 2009 at 11:28:06 AM
Page generation time: 0.3725
