20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Seemingly simple swept blend
10 Posts No Rating |
Hi there,I'm currently modelling a bar and the bar top has me stumped. As the pictures below will illustrate i am trying to transition from one profile to another at the corner of the bar.
please refer image: goal.jpgA swept blend seemed the obvious weapon of choice however when i attempted to employ this method, the resulting solid swings out in such a manner that the edge no longer remains tangent.
please refer image: result.jpg
Just to be clear i am trying to achieve the transition in a smooth manner (tangent to tangent) to show clients a reasonably accurate perspective shot.
I think you will have to do this in two stages with a profile at the miter (which which will not be a 45).
There really was no reason to model this as you did. A simple flat extruded counter with a radius void for the edge would have been easier. Then do the correct cut profile as detail line work in detail sections.
Thanks for the response WWHUB, unfortunately i need to have it modelled for a perspective shot.
You don't understand. Model it. Don't use a swept blend. You don't need to model the notch though. Just what will show. Mich be easier as an in place family with two seperate extrusions (or 2 sweeps) then use a void for the junction area.
Edited on: Tue, Mar 27, 2012 at 7:33:27 AM
Yeah finally submitted and did that yesturday.
Swept Blend |
Fri, Nov 28, 2008 at 4:39:26 PM
Please help me with swept blend!! |
Mon, Jul 28, 2014 at 3:31:14 PM
Swept Blend for Basin |
Tue, Oct 31, 2017 at 3:38:16 AM
cannot rotate the reference plane of a swept blend |
Tue, Feb 23, 2010 at 6:22:35 AM
Swept Blend Wall |
Wed, Jun 24, 2009 at 4:37:36 AM
13
