Forums >> Revit Building >> Technical Support >> Revit mep
Sat, Mar 24, 2012 at 4:03:14 PM | Revit mep
idraw38
I'm trying to draw a dwv layout. I do not want an autorout solution but when I try to connect pipes and fittings, I get an error message that there is no auto route solution. Is there any way to disable this feature?
Carl
Mon, Mar 26, 2012 at 8:07:47 AM | Revit mep
jterrell
3 Stars: 5 Votes
Make sure your pipe system has fittings defined.
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
From 2D CAD MEP files to Revit MEP
Tue, Feb 9, 2010 at 11:12:10 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Page generation time: 1.4530
