Forums >> Revit Building >> Technical Support >> Wall Sweep Category
Fri, Mar 23, 2012 at 12:43:34 PM | Wall Sweep Category
rhecht5000
Hello,
Wall sweeps I created for stucco banding on an exterior wall say "by category" in the mateial column.  What category are they?  Changing the walls->Wall Sweep-cornice material has no effect.
Thanks!
Ron
Fri, Mar 23, 2012 at 5:06:57 PM | Wall Sweep Category
If you did not assign them anything then thy will probably just be grey.  You have to assign he material in properties.  Naming them doesn't mean anything.
I can't tell you how to assign the material because I don't know how you created the sweep.  In-place element sweep - what?
Problem with wall sweep show on wrong sections
Wed, Mar 22, 2006 at 5:37:32 AM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
How to Load a Wall sweep type
Mon, Jun 9, 2008 at 12:42:29 PM
Hosted Wall sweep
Thu, Jul 28, 2005 at 10:10:34 PM
Page generation time: 1.9554
