Forums >> Revit Building >> Technical Support >> basement level?!
Mon, Dec 19, 2005 at 2:39:50 PM | basement level?!
archeng82
I want to start a new project that has a basement level. Should I set the level to a negative number(the level height) below level 1 which is set to 0 (zero)?! If so, would that effect the rendering later on?! Thanks.
Mon, Dec 19, 2005 at 3:36:17 PM | RE: basement level?!
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No. If you are using the auto ground plane you will just need to adjust it accordingly.
Mon, Dec 19, 2005 at 4:28:42 PM | RE: basement level?!
archeng82
I'm sorry, but what is "the auto ground plane"? Could you explain more?!
Mon, Dec 19, 2005 at 5:31:08 PM | RE: basement level?!
eldados
eldados Avatar
4.5 Stars: 8 Votes
you can take your basement level to what ever you want, it is not going to affect rendering, what Mr spot means, is turning off the ground plane when it comes to rendering, which is in the rendering settings.
Integrator
KarelCAD
Mon, Dec 19, 2005 at 6:16:12 PM | RE: basement level?!
archeng82
How can I turn off the ground plane?! Do I have to uncheck the checkbox, then hit save?! Because I've tried many times unchecking the ground lane option checkbox, but it keeps coming back the same..!!
Mon, Dec 19, 2005 at 9:56:11 PM | RE: basement level?!
Rythmick
5 Stars: 2 Votes
You need to turn the ground plane off in two areas, "Advanced Visability Graphics" and in the render settings in the advanced "Environment" .
Basement Datum Level Line: Now you see it, now you don't
Fri, Nov 18, 2011 at 11:41:49 AM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Level 1 room boundries showing up in foundation level
Fri, Feb 15, 2008 at 9:31:36 AM
Can't insert doors/components in level
Thu, Apr 14, 2011 at 11:20:19 PM
Basement Wall Function: "Foundation" or "Exterior"?
Fri, Mar 26, 2010 at 12:27:21 PM
Page generation time: 2.1534
