Forums >> Revit Building >> Technical Support >> Muntin parametric array for a window
Wed, Mar 21, 2012 at 11:03:36 AM | Muntin parametric array for a window
jsel13
I’m trying to have multiple window sizes with a different number muntins in each one.
I’ve set up an array but I’m having a bunch of issues.
one is where do i start the array? the muntin needs to start off of the lower frame but if the spacing changes every time how do i locate the starting point for each window size.
second is I can’t seem to get the muntin to lock horizontally. i made a line based family for the muntin because I thought I’d be able to lock it but it doesn’t seem to be working. I’m getting all kinds of errors.
it’s an existing building and I need the detail in the muntin if you were going to ask why there is a profile to the muntin itself and not just a rectangle
I've attached the family for reference.
please help Winking
Wed, Mar 21, 2012 at 2:59:27 PM | Muntin parametric array for a window
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
As far as the array goes, you will need to create a formula that states the distance between muntins when the window changes, your start point of the array will be your first click when you attempt array I believe.  There are a few examples on the forums here you should try to search.
Wed, Mar 21, 2012 at 3:01:40 PM | Muntin parametric array for a window
I would really start with a working window family.  I believe Pella and Anderson have som that have different number of lites.
Thu, Mar 22, 2012 at 10:55:28 AM | Muntin parametric array for a window
LIZARD2806
3.5 Stars: 7 Votes
Marvin has made very good progress in their bim library and they actually already have windows where you can define the number of lites.  Andersen has a family generator which is a plugin for revit.  You use their software to define the windows and detials, then export ot revit and their proigram makes a revit family for you.  Unfortunately, it isn;t perfect but it works very nicely in many cases.
Parametric Arrays
Fri, Feb 5, 2010 at 3:19:22 AM
Parametric Array
Wed, Feb 8, 2006 at 11:14:52 AM
Muntin Thickness
Wed, Aug 12, 2009 at 3:13:33 PM
Centering a parametric array in a family - RAC 2009
Thu, Jul 16, 2009 at 12:10:04 PM
Window Family with Muntins
Fri, May 8, 2015 at 1:36:20 PM
Page generation time: 0.9639
