Forums >> Community >> Newbies >> New to Revit and Need help
Wed, Mar 21, 2012 at 8:17:26 AM | New to Revit and Need help
andrewnet82
Hi, I'm studying Building Services Engineering at University and as part of my project I wanted to create a building model on Revit.
I have managed to self teach myself the basics, which was a challenge in its own right, but very rewarding at the same time.
I am now stuck on 3 parts of my building:
1 - Creating a flat roof
2 - Spiral Staircase
3 - MOST IMPORTANTLY!!! creating the external finish to look like glass like the attached file.
My major concern is time, I only have 1 week to submit the final model, could someone please do this for me if I email them my project separately.
This would be a massive help as I'm struggling right now!!!!
Thank You.
Wed, Mar 21, 2012 at 8:20:26 AM | New to Revit and Need help
andrewnet82
Hi, Ive attached what I've done up to now in PDF format
Thanks
Wed, Mar 21, 2012 at 9:17:00 AM | New to Revit and Need help
LIZARD2806
3.5 Stars: 7 Votes
1. Create a flat roof like a normal roof, but be sure that each line is set NOT to define pitch.  No pitch=flat roof.  Note, though that it will need SOME amount of pitch when built, though this could be tapered insulation and you can create a new roof type with a variable portion on top so you can adjust the pitch on it, but the underside (presumably metal deck) will be flat.
2. There is a family in the download section.  I am not sure you can make a spiral staircase wiht the stair tool.  You can make a circular staircase, but not a spiral staircase.  The stair tool is limited to 360 degrees, meaning you can;t overlap.
3.  As for the  materials, it is as simple as applying the right material (glass) to the wall.  I would imagine you used a curtain wall, in which case it should be glass already adn you can adjust the transparency and properties in the materials dialog.
As for doing it FOR you,......"give a man a fish, and you feed him for a day, teach a man to fish and you feed him for life"
It shouldn;t take long for you to do this.  good luck!
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 1.3355
