Forums >> Revit Building >> Technical Support >> family wont load
Mon, Mar 19, 2012 at 4:17:48 PM | family wont load
joewallace
i made a family for a block model of a site im doing but when i load it into a project nothing comes up. i cant understand what im doing wrong, can anyone help please
Mon, Mar 19, 2012 at 4:47:26 PM | family wont load
LIZARD2806
3.5 Stars: 7 Votes
Check the following, if you haven;t already:
1.  Zoom extents in a default 3D view to make sure it isn;t placed somewhere else.
2.  If you don;t see it after #1, above.  Click the light bulb to show hidden elements and zoom extents again.
3.  If that doesn;t work, check your view properties (VV) to see if something is turned off.
Mon, Mar 19, 2012 at 4:56:48 PM | family wont load
joewallace
i tried all of those and nothing works, i used load into project then tried to load family on the menu bar and it asked me about over writing it so its there somewhere but i still cant find it
Mon, Mar 19, 2012 at 5:55:01 PM | family wont load
TKennedy
4 Stars: 8 Votes
Make sure you are looking in the correct category in the project browser. If you are unsure of the category, open the family and look in Family Categor and Parameters. It may not be set to what you think it is.
Tue, Mar 20, 2012 at 8:19:57 AM | family wont load
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Go to the project browser, find it under families and drag and drop the family into your project.
Tue, Mar 20, 2012 at 2:25:22 PM | family wont load
jlights
3 Stars: 2 Votes
Make sure you are putting on the appropriate workset if you are using worksets. if you are putting it on a workset that is turned off in that view, you won't see it. Turn on all worksets and see if it appears, move it to the right workset, and turn off the worksets you don't need.
It might also be that the family's category is turned off in that view. Check to see what the family's category is and make sure that category is visible in that view.
Open the family and make sure that it is visible in plan view or whatever view you are using in the project. If the family geometry is turned off in plan view, it won't show up in your plans, but it will still be in the project. Either turn the geometry on, or, better, leave it turned off and create a 2D symbolic representation of it in plan view Cryingusing symbolic lines), which will be visible in project plan views.
Make sure that you are placing the family within the view range of the view. If it's outside the view range, it won't show.
Hope this helps.
jlights
Wed, Mar 21, 2012 at 10:39:48 AM | family wont load
joewallace
thanks for the help everyone, i finally got it working
the family mass wont load into my project
Wed, Nov 10, 2010 at 1:46:28 PM
Cant figure out why Family wont load into project
Thu, Jun 17, 2010 at 10:45:17 AM
Cant load families
Tue, Jan 5, 2010 at 12:05:32 PM
Cannot load family
Mon, Apr 18, 2011 at 5:22:02 PM
Reivt will not load door family
Tue, Oct 11, 2011 at 7:23:13 AM
Page generation time: 2.0219
