Forums >> Revit Building >> Technical Support >> Glass Paneling for Skyscraper
Mon, Mar 19, 2012 at 4:03:42 PM | Glass Paneling for Skyscraper
bschwartz89
Hey guys so I'm pretty new to Revit and for a class project we were asked to model a tower/building.  I decided to go witht the Petronas Towers.  I have the basic structure all made using the conceptual massing tools and its imported to a project.  I'm trying to apply a nice looking glass paneling so that it looks somewhat realistic.  Whats the best way about applying such a paneling?  Should I just use the curtain wall feature on all of the faces?  And I don't exactly have the time/experience to make my own curtain wall so is there a default one that should work fine for what I need?
Thanks for any help/information!
Tue, Mar 20, 2012 at 2:04:30 AM | Glass Paneling for Skyscraper
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
There are two main tools for curtain walls. The default one only allows vertical panels. You can create your own, its not really hard, just google it a lot of videos, tutorials, step by step will come out.
If you need advanced curtain walls (for example, a curved facade or a inclined curtain wall) for the proyect you need then go to the autodesk page and learn the basic of the mass environment and adaptive panels. A good site for studying that its buildz.blogspot.com. , i ve learn a lot from there. Hope it helps
Solid Paneling Help
Thu, May 22, 2008 at 11:18:53 AM
Building 20+ story skyscraper/highrise how do make outer structure?
Mon, Mar 28, 2011 at 10:27:03 PM
wood paneling to a wall
Thu, Apr 22, 2010 at 7:24:53 AM
Creating a paneled wall
Fri, Apr 15, 2011 at 9:07:26 AM
Transparency of glass windows in 3d views
Wed, Aug 5, 2009 at 10:43:37 AM
Page generation time: 2.1636
