Forums >> Revit Building >> Technical Support >> Square Yards calculations
Mon, Mar 19, 2012 at 9:59:58 AM | Square Yards calculations
MarkBryanDesign7
Is there a way to have revit calculate the square yards for a material that is assigned to a seat? It calculates the square feet so would I change the formula and multiply it by .111?
Mon, Mar 19, 2012 at 10:02:37 AM | Square Yards calculations
LIZARD2806
3.5 Stars: 7 Votes
If you are trying to schedule this, yes.  If you are trying to have it report square yards in the properties window, to my knowledge, no.  IN a schesule, you would simply add a calculated value field.
Mon, Mar 19, 2012 at 1:27:11 PM | Square Yards calculations
TKennedy
4 Stars: 8 Votes
You might be able to change your project units. If just need it in a schedule, you can change the units in that column instead of using a calculated value.
Mon, Mar 19, 2012 at 2:30:11 PM | Square Yards calculations
LIZARD2806
3.5 Stars: 7 Votes
Square yards is not an option for project units.  I checked.  As the schedule uses the same project settings dialog box, it won;t have square yards either.  I double checked to be sure.  Unless someone else has more ideas, calculated values is the only option if you need to use square yards.
Mon, Mar 19, 2012 at 3:00:43 PM | Square Yards calculations
TKennedy
4 Stars: 8 Votes
Good to know.
Dimensioning with yards
Tue, Apr 27, 2021 at 3:42:11 PM
Room Tag w/ Dimensions and other calculations
Thu, Apr 29, 2010 at 1:15:40 PM
ComCheck Energy program area calculations
Wed, Mar 26, 2008 at 11:38:06 AM
area calculations
Wed, Dec 31, 2008 at 1:17:45 PM
Shear Wall Calculations using Revit !!
Fri, Nov 21, 2008 at 4:03:36 AM
Page generation time: 0.3787
