Forums >> Revit Building >> Technical Support >> Opening numbers
Sun, Dec 18, 2005 at 11:54:06 PM | Opening numbers
cadjockey
Hi all, There's nothing worse than having to place a new door or window into your plan after you have worked out the sequence of opening numbers on your sheet from door to window to door etc. Can revit adjust the sequence of opening numbers so that the sequence of numbers flows from opening to opening as you read the plan if I need to place an extra door or window right in the middle of current sequence? cadjockey
Mon, Dec 19, 2005 at 1:14:21 AM | RE: Opening numbers
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nope unfortunately not. And many of us are hanging for that ability.
Mon, Dec 19, 2005 at 1:55:05 AM | RE: Opening numbers
eldados
eldados Avatar
4.5 Stars: 8 Votes
Like mr. spot said we are hanging... a good workaround is to number your windows and doors as part of your room number. that way if you change a window or door, you only need to change the ones in that room. it's always a good idea to work with room numbers... HTH
Integrator
KarelCAD
Mon, Dec 19, 2005 at 3:07:29 AM | RE: Opening numbers
cadjockey
Hi guys, What a let down. A bit like not being able to customise arrow heads. What's up with that? You can manipulate everything else with amazing detail. I hope the developers are listening to the needs of the market. cadjockey
element I.D. numbers
Mon, Aug 25, 2008 at 1:41:33 PM
Floor and shaft opening issues
Fri, Nov 4, 2016 at 3:41:50 PM
2013 revit new sheets not opening in correct discipline
Tue, Mar 18, 2014 at 8:55:36 AM
Arched Opening Problems
Tue, Jan 18, 2005 at 5:06:11 PM
Opening cut and Void cut not allowed
Thu, May 2, 2013 at 2:29:16 PM
Page generation time: 0.1212
