Forums >> Revit Building >> Technical Support >> Formula inconsitency on REVIT WikiHELP?
Wed, Mar 14, 2012 at 8:22:58 PM | Formula inconsitency on REVIT WikiHELP?
MongooseST1
MongooseST1 Avatar
I am having difficulty understanding the match form the REVIT help site(link is below) on d=R*h. If youuse the numbers provided one does not come up with 266.7 for d. 567 x 300 = 170,100. How are they getting 266.7?
Circular Segments.Here's how to calculate the Segment length, the Chord Length, the Angle etc. (Image should speak for itself)
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Families%2c_Parameters%2c_Formulas/Formulas_for_%22Everyday%22_Use
Wed, Jun 6, 2012 at 5:55:02 PM | Formula inconsitency on REVIT WikiHELP?
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Because the formula is not R * h , as you say, but R - h .
Planta1 Revit Online Consulting | info@planta1.com
Revit Wikihelp
Tue, Oct 1, 2013 at 10:28:07 AM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula
Fri, Mar 5, 2010 at 12:09:09 PM
need help with a formula for my calculated value
Thu, Jan 30, 2014 at 1:03:02 PM
Page generation time: 2.8297
