12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Cuts through Ramps in plan view
10 Posts No Rating |
Does anyone know if there is a way of making a plan view NOT show the cut through the entirety of a sloping slab and beams (Floor family).
My plans are showing a multi-level carpark and the resulting cut through the floor in plan view (see attachment) is very confusing.
Only solution would be to adjust the cut plane for this section using a plan region or adjust your overall view range settings so it doesn't cut the floor.
Unfortunately as the carpark is multilevel and the floor is a 'corkscrew' type structure the plan view HAS to cut through the floor somewhere - moving the cut plane will only shift the problem to somewhere else......
Is it possible to combine a partial plan view of one floor with a partial plan view of the floor below onto one sheet (so that it looks like a single plan view without showing a cut through floors) ??
Any other possible solutions?
Post edited on 2005-12-19 01:51:09
A plan region will be the best solution around the ramp, use it to minimize the amount cutting, than you might use a solid white region hatch and some drafting lines...
HTH
Actually yes - the plan region tool is exactly what I'm looking for (I misunderstood Mr Spot's original answer).
Thanks
Plan cuts incorrectly at windows despite correct view range |
Thu, Aug 6, 2009 at 9:12:23 PM
Shadow problems with ramps |
Fri, Jun 22, 2012 at 11:56:18 AM
Attach Walls to Ramps |
Fri, Feb 18, 2011 at 6:45:16 AM
plan view cut plane inexplicably omits objects that it cuts. |
Tue, Mar 3, 2009 at 3:54:46 AM
Showing break lines with Ramps and Stairs |
Mon, Jul 30, 2018 at 11:02:36 AM
