11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> LINE WEIGHT PROBLEM IN PRESPECTIVE
Tue, Mar 13, 2012 at 2:44:12 PM | LINE WEIGHT PROBLEM IN PRESPECTIVE
liorman
5 Stars: 3 Votes
Hi all,
I have checked my line weight setting (model and prespective views) which looks fine and my object style -also okay-but in prespective views (also when tring to rrender them almost all the lines becoming so heavy you can barely see something. The line weight seems to look okay in 3d views (the non- camera views and in elevations) any suggestion?
Edited on: Tue, Mar 13, 2012 at 3:34:38 PM
Tue, Mar 13, 2012 at 2:56:44 PM | LINE WEIGHT PROBLEM IN PRESPECTIVE
This might be an image size problem.  When you click on the 3D image frame, what is your crop region size shown on the option's bar?  Image size and pixels are two different things.
Tue, Mar 13, 2012 at 3:26:45 PM | LINE WEIGHT PROBLEM IN PRESPECTIVE
liorman
5 Stars: 3 Votes
Thank you WWhub for the repy
It didnt work. I have multyplied the image size by 3 but it didnt worked out. The image rendered fine when sending it to the autodesk rendering cloud but since they dont give the option to choose your background I will have to do it in my machine. Any more ideas?
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:58 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:55 PM
Wall sweep line weight
Tue, Apr 24, 2012 at 2:58:39 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Page generation time: 3.5664
