Forums >> Revit Building >> Technical Support >> Redefining the reference level
Tue, Mar 13, 2012 at 2:26:36 PM | Redefining the reference level
arusso5
Using Revit Arch 2012.
I have a existing building reno project with a ton steel (over 4500 pieces).  The guy who laid out the floor steel and bar joist used reference levels and we'd like to switch that to reference planes.  I started selecting the pieces by level and using 'Edit Work Plane,' which will allow me to set to the ref plane I want, butin the properties window it says its still constrained to the original ref. level.  Is there a way to clear that w/o having to completely rebuild?
The reason for the switch is the original user set the levels as T.O.S. 01, 02, etc, not exist. T.O.S. 01 and another user moved the levels for 2 new additions instead of creating new steel locations. Ugh.
Thanks for the help.
Tue, Mar 13, 2012 at 2:54:29 PM | Redefining the reference level
Why change these?  Set up new levels and copy / paste from the level that moved to the correct level.... AND NAME THE LEVELS BETTER!
Reference planes Revit 2015 in massing environment
Thu, Jun 12, 2014 at 12:01:38 PM
How to change Window Reference level in Window Schedule
Fri, Sep 16, 2011 at 9:49:17 AM
2 Out of 6 Reference Planes are not visible
Sun, Jul 13, 2008 at 4:52:58 AM
Building only from one level and two reference planes
Tue, Mar 16, 2010 at 2:54:26 PM
reference plane as level
Thu, Apr 20, 2006 at 1:06:07 PM
Page generation time: 0.6686
