23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> duplicate view with dependent indication
50 Posts No Rating |
I have created a duplicate as a dependent view to facilitate breaking my plan into multiple views. This has resulted in a dashed line indication in the overall plan. Is there a way to turn this line indication off? I am creating an overall plan (for an SK) and don't want these line showing up
Thanks
VG / Annotation tab / Match line
thanks hub, but matchline didn't do it.
The dashed line is a rectangle which represents the extent of the clipping for the dependent view that was created.
I guess that the easy way would be to create a duplicate view of the plan that can then be used for my SK drawings, but it seems there should be a way to turn it off and not have to create all these duplicates for use in mulitple sheets
A rectangle ???? It sounds like you created a callout, not a dependent view.
Nope it's a dependent view. I just did it again to test it.
I have my level 1 plan. Create a dependent view. rename the dependent view "plan north".
within the dependent view, I adjust the crop to view just the north end of the plan.
When I go back to the Level 1 overall plan I see a rectangle that corresponds to the Crop of the dependent view which is very helpful, However it I can't seem to turn it off as needed.
Just right click on it and hide in view - element.
Thanks Hub,
Always the simplest solution overlooked..
Matchlines and Duplicate Dependent Views |
Thu, Nov 29, 2007 at 8:01:42 AM
Dependent views not the same as Parent view... |
Fri, Jun 16, 2017 at 11:02:18 AM
Error Converting Dependent View to Independent View RAC 2009 |
Fri, Oct 3, 2008 at 8:53:23 AM
Adding views to a sheet - get all the clip rejoins the same? |
Thu, Dec 20, 2007 at 8:35:43 PM
Duplicate views create duplicate callout tags in referring views... |
Fri, Mar 9, 2012 at 1:37:25 PM
