Forums >> General Discussion >> Revit Project Management >> Revit Time Sheets or Revit Time Cards? or maybe at stop-watch plugin?
Mon, Mar 12, 2012 at 5:15:59 PM | Revit Time Sheets or Revit Time Cards? or maybe at stop-watch plugin?
Polar
Has anyone set up a time sheet or time card in Revit? I just used a schedule with formulas and parameters/variables to calculate occupancy loads for a couple of projects and started thinking that if I could record time directly and have it tabulate / total time it would make it easier to stay on top of how I spent my time....
Any thoughts?
Thanks!
Tue, Mar 13, 2012 at 7:33:29 AM | Revit Time Sheets or Revit Time Cards? or maybe at stop-watch plugin?
No way to do it in native Revit and I haven't seen any add-ons for it.  Just external packages. Here is the closest I've seen from Revit but it really isn't.
http://forums.augi.com/archive/index.php/t-1094.html
IS ACCURENDER NXT PLUGIN WORKING ON YOU REVIT 2009?
Tue, Nov 25, 2008 at 6:29:33 AM
SheetLink (Free Revit Plugin) - Import/Export Data
Mon, Dec 17, 2018 at 7:08:26 AM
Is render time in 3D Max faster then render time in Revit?
Mon, Jun 1, 2009 at 11:20:56 AM
Print to PDF sheets with DWG files on them help. Maybe Bluebeam help
Mon, Oct 26, 2015 at 10:55:35 AM
Revision Number for sheet issued for the first time [ 1 2 ]
Tue, Oct 15, 2013 at 10:05:01 AM
19
Page generation time: 4.8119
