13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Revit to DWF walls missing
52 Posts No Rating |
hi,
i have converted Revit sheets to Dwf files, i see that some of the wall, lines etc inbetween are not too be seen in DWf file. Type, pattern and other properties of the wall, line are similar and are seen in Revit files.
Waht may be the reason, can anyone suggest me regarding this.
Thanks,
what about when you print to PDF? do you see the walls?
I will suggest to reinstall the DWF writer, could be that the driver is corrupt...
DWF Linking |
Thu, Aug 23, 2007 at 12:55:32 PM
Revit views to DWF format to print |
Fri, Mar 19, 2010 at 12:21:41 PM
Can anyone help me understand DWF's in Revit...Please? |
Wed, Jun 21, 2006 at 1:22:46 PM
Does anyone have a Brick Arch Family? |
Fri, Dec 4, 2009 at 6:42:36 AM
Revit 2012 - export DWF - corrupt dwf file |
Fri, Aug 3, 2012 at 10:47:11 AM
