Forums >> Revit Building >> Technical Support >> Creating a new view set in the project browser
Sun, Mar 11, 2012 at 2:12:31 PM | Creating a new view set in the project browser
COUGARBRENT
I am trying to creat a new view set in the project browser in addition to the ones already there (floor plans, clg plan, elevations, 3d views etc.)  I am having a fair amount of difficulty doing this. Iwould like to have a new view for electric plans.  Can anyone point me in the right direction?
Sun, Mar 11, 2012 at 9:49:08 PM | Creating a new view set in the project browser
Phaeax
Pretty simple fix. I am not sure if it is exactly what you want though because Revit might not allow you to add your own.
You will need to change your browser configuration type to By Discipline. Then change the plan you wish to be in electrical to electrical via the view properties under discipline.
This should separate your sheets by discipline.
Mon, Mar 12, 2012 at 7:56:35 AM | Creating a new view set in the project browser
You can add addition parameters to views and use those to sort your browser.  Read some of the similar threads below or do a search of the forums.  Sort should be a good search word.
Create sub menu in Project Browser Floor Plan Views
Tue, Jan 1, 2013 at 8:34:40 PM
Browser organization - problems using view template
Fri, Apr 26, 2013 at 9:56:27 AM
Project Browser Grouping Parameters
Wed, Feb 11, 2009 at 2:01:23 PM
Project Browser stay floated?
Fri, Jul 15, 2005 at 12:03:28 AM
Project Browser Missing!!!
Thu, Oct 4, 2012 at 3:47:37 PM
Page generation time: 1.4904
