Forums >> Revit Building >> Technical Support >> Faint lines showing from ground floor on first floor
Fri, Mar 9, 2012 at 5:22:58 PM | Faint lines showing from ground floor on first floor
hasnaat2011
hi i am doing a drawing and faint lines of the walls and other components that i have drawn on the ground floor are showing very faintly in the second floor is there a way to get rid of this and i have attached a picture below.
Sat, Mar 10, 2012 at 5:54:59 AM | Faint lines showing from ground floor on first floor
4 Stars: 205 Votes
In that view change the "Underlay" to "None"
Sat, Mar 10, 2012 at 4:40:33 PM | Faint lines showing from ground floor on first floor
hasnaat2011
THANX very much
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:10 AM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
how to see upper levels dash lines at the ground floor?
Thu, Dec 24, 2009 at 2:26:32 AM
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:04 AM
Page generation time: 5.1269
