Forums >> Revit Structure >> Technical Support >> elevation tag
Fri, Mar 9, 2012 at 11:33:56 AM | elevation tag
davidlowery
OK, can anyone tell me how to make a tag that would read:
 W14X22 (114'-6")
in which the 114'-6" is the "live" elevation (it changes according to the actual beam elevation.)
I don't want an offset value.  I want an actual value.  If the finished floor el is at 100'-0", the beam is at 114'-6", not 14'-6".
Using the "start level offset" parameter in the elevation label only works if I create a level at negative 100'-0". But then I have to place my beams at negatiev 100, and then I have to go back and offset them 114'-6", which is too stupid.
It seems that Revit thinks that everyone only needs an offset value instead of an actual value.
I want to place my beams at whatever reference level I am at and have the tag give the ACTUAL ELEVATION of the beam, not the offset from the level I am at.
I have played with the family parameter thing forever.  I think I need a new parameter that just adds a hundred feet onto the offset value, but I can't seem to get the formula syntax down or even apply that parameter to my label.
Fri, Mar 9, 2012 at 11:47:56 AM | elevation tag
Why don't you just set yor elevation to project rather than relative?
Fri, Mar 9, 2012 at 11:51:57 AM | elevation tag
davidlowery
How do I do that?
Fri, Mar 9, 2012 at 12:03:19 PM | elevation tag
Like attached
Fri, Mar 9, 2012 at 12:22:12 PM | elevation tag
davidlowery
I don't have a spot elevation thingy loaded for beams, only for walls.  CryingSee image) How would I load one?
Fri, Mar 9, 2012 at 12:39:57 PM | elevation tag
davidlowery
So it's picking the lesser of 2 evils:
Either go with the beam tag and have the parenthesis but an offset value instead of actual  --(14'-6")
OR
Go with the spot elevation and no parenthesis, but the elevation can be set to be correct  --114'-6"
And there's no way to get into that spot elevation and use its parameters in a beam tag?
And you have to go to a fine detail view to do spot elevations on a beam and then switch back to coarse?
Sheesh....
Fri, Mar 9, 2012 at 12:47:44 PM | elevation tag
All spot elevation tags can be modified to use project elevation.
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
updating/changing elevation tag types
Wed, Mar 19, 2008 at 9:49:46 AM
Elevation tag
Thu, Nov 1, 2007 at 3:06:21 PM
if I happen to put two elevations on different sheets on the same elevation tag
Wed, Jan 12, 2011 at 3:00:58 PM
Page generation time: 0.2866
