Forums >> Revit Building >> Technical Support >> Wall sections cut from elevation... now not seen on plan
Fri, Mar 9, 2012 at 10:56:27 AM | Wall sections cut from elevation... now not seen on plan
IloveSKETCHUP
I cut all of my wall sections from the elevations and I noticed they do not show up in plan.
I would just redo them cut from plan (as I notice they will show up in elevation) but I have done all my call-outs.
Is there any way to get these to show up in plan or do I have to chalk it up and re-cut them in plan view.
Fri, Mar 9, 2012 at 11:05:12 AM | Wall sections cut from elevation... now not seen on plan
TKennedy
4 Stars: 8 Votes
Check the properties for the section views, make sure 'Hide at scales coarser than' isn't set higher than your plan view. If it's not that, check VG in the plan views and make sure sections are not turned off. If it's not that, make sure your sections go through your plan's view range.
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Sections Referencing the drawing you want. Help Cheat!
Fri, Feb 25, 2011 at 11:22:05 AM
joinery cut at different levels in plan
Fri, Feb 26, 2016 at 4:28:15 AM
Why does the wall opening cut only go up 2/3 the height of the wall?
Sun, Feb 18, 2007 at 8:53:25 AM
Page generation time: 5.8088
