Forums >> Revit Structure >> Technical Support >> Spot Coordinates on Piles
Fri, Mar 9, 2012 at 8:57:10 AM | Spot Coordinates on Piles
g1lly83
Hi, new user here,
just tring to do some spot coordinates on piles, but it wont let me select the centre point (insertion point), it will
only allow me to pick the horizontal line or vertical line. How on earth do i selcet the centre point?
cheers in advance
gilly
Fri, Mar 9, 2012 at 9:09:59 AM | Spot Coordinates on Piles
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe you can only select the edge of objects (or defining lines) with spot coordinates.
Fri, Mar 9, 2012 at 9:11:10 AM | Spot Coordinates on Piles
g1lly83
cheers for that,
bit silly aint it oh well
Settings for spot coordinates - Revit 2012
Fri, Jun 8, 2012 at 4:08:37 PM
Aquiring Coordinates
Wed, Feb 10, 2010 at 10:22:37 AM
a thick question from someone who should know....
Tue, Mar 17, 2009 at 11:25:08 AM
How to model long ground beam with piles?
Mon, May 16, 2016 at 1:51:14 PM
Creating a Pile Schedule
Mon, May 23, 2011 at 10:37:27 AM
Page generation time: 0.4635
