22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> exact angle copy of existing, or round off
Hi, I have a new project that is a ranch home, its existing, Im adding to it.
My Question is this: One wing of the home is parallel with a property line that is angled at 34 degrees, 27 minutes, 22 seconds! and I know people draw to true in Revit, but is it wise to match that angle, or just go with say 34 or 35 degrees, and draw that up...does it matter?
If you want the building parallel to the site, then do that - no matter what the angle. But then document your building square with the view window.
YES. After you draw the site, your TRUE NORTH and PROJECT NORTH will be the same. Rotate PROJECT NORTH so it is parrallel or perpendicular to the building. I did a tutorial in here on doing this, but it never made it to the tutorial section. You should be able to find a forum that explains doing this. If not, let me know.
To answer you rquestions if it matters, obviously not that much, but every thing you do down the line will be a little bit wrong: sun shadows, property setbacks, etc. It is far better to set the drawing up correctly to start.
HTH
**Using Revit Architecture 2009, 2011, and 2012** |
existing building at an angle. |
Mon, Jul 1, 2013 at 7:45:19 AM
Adding quarter round moulding to existing base board moulding |
Tue, Nov 20, 2007 at 8:43:48 PM
Angle Parameter in family |
Mon, Oct 12, 2020 at 7:55:09 AM
Round roof with round porch |
Fri, Jul 31, 2009 at 2:12:27 PM
Round Shafts |
Wed, Dec 17, 2014 at 7:00:27 AM
