Forums >> Revit Building >> Technical Support >> Wrong level view of window familly in floorplan
Thu, Mar 8, 2012 at 9:23:16 AM | Wrong level view of window familly in floorplan
BouwbureauSklad
Hi there,
I made a window family from a door with an upper light. In the floorplan I would like to see the horizontal section at about 1500mm plus floor. According to my view range. For some reason I can only see the horizontal section of the window his upper light. Does anyone has an answer how to get the correct section visible in the floor plan. See my attached images.
Best regards
Henk / Netherlands
Edited on: Thu, Mar 8, 2012 at 9:38:26 AM
Thu, Mar 8, 2012 at 9:34:07 AM | Wrong level view of window familly in floorplan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Why did you make a window in a door family?  That could cause you problems.
Thu, Mar 8, 2012 at 9:43:46 AM | Wrong level view of window familly in floorplan
BouwbureauSklad
Well this certainly is not my day today. Even changing some attached pictures becomes messy...
I could try drawing a door in a window family. But is there a way to determine at which level of height a window or door family is visible in the floor plan ?  Strange that this visibility doesn't follow the general view range settings.
Thu, Mar 8, 2012 at 9:49:31 AM | Wrong level view of window familly in floorplan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No you are right with the light in the door family, I was just reading the description of your problem wrong, sorry.  Are you sure that all of your visablility elevations are correct?
Thu, Mar 8, 2012 at 9:49:42 AM | Wrong level view of window familly in floorplan
In your family, set your plan view range at that cut level.
AND reload the family.
Edited on: Thu, Mar 8, 2012 at 10:01:26 AM
Thu, Mar 8, 2012 at 11:02:25 AM | Wrong level view of window familly in floorplan
BouwbureauSklad
I tryed deleting and replacing the family with adjusted view range settings but the effect is just the same. The difference in view settings in the former window was only 50 mm above the cut plane in the project file or floor plan.
Edited on: Thu, Mar 8, 2012 at 12:11:10 PM
Thu, Mar 8, 2012 at 12:19:31 PM | Wrong level view of window familly in floorplan
The problem is probably the visibility of your components in the window area of this family.  Change it from visible in plan to visible when cut in plan.
Thu, Mar 8, 2012 at 3:13:09 PM | Wrong level view of window familly in floorplan
BouwbureauSklad
Thanks for your answers. I didn't fix it yet but I know now that it has something to do with the profiles. They look allright in the family drawing but they are flipping in the project file. (And dissapear in the walls) I quess I will have to delete and reload them in the project file. Strange because the problem didn't occur in a standard window family.
Edited on: Thu, Mar 8, 2012 at 5:40:35 PM
Fri, Mar 9, 2012 at 2:47:18 AM | Wrong level view of window familly in floorplan
Dafpfy
3.5 Stars: 11 Votes
would you mind uploading the family?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Sat, Mar 10, 2012 at 11:23:17 AM | Wrong level view of window familly in floorplan
BouwbureauSklad
I tried uploading a dozen times whithout succes but here is a link to a small project file (revit 2012) with two similar families with light above the door and whithout it.
http://www.mijnbestand.nl/Bestand-ZVBJSTVTBMYC.rvt
Mon, Mar 12, 2012 at 4:29:01 AM | Wrong level view of window familly in floorplan
#11
Dafpfy
3.5 Stars: 11 Votes
Select your window frame between top en bottom part and go to visibility settings,
uncheck plan/rcp
do the same for the top glass part.
Kind regards,
D
peace is the path."
Mahatma Gandhi.
Mon, Mar 12, 2012 at 4:45:10 AM | Wrong level view of window familly in floorplan
#12
BouwbureauSklad
Wauw ! It worked. Thank you very much.
Best regards
Henk Koster
view range for floorplan views
Tue, Sep 27, 2005 at 2:41:03 PM
Tiled View changing
Fri, Apr 17, 2015 at 10:20:39 PM
View Range Cut Plane Associated Level is wrong
Fri, May 4, 2012 at 11:46:09 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:10 PM
Floorplan visibility in the 3D view?
Tue, Mar 23, 2010 at 2:09:06 PM
Page generation time: 1.7138
