12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Help with Frame generator
2 Posts No Rating |
Hello,
I am trying to create a fairly simple frame system using the Frame Generator extension but I receive an error message each time. The error message is "Line length is too small for Revit tolerance. Parameter : end point." I have set the Project units in meters/cm, I have tried changing the sections of the elements. Nothing helps. The frame structure is quite simple, with 4 bays and 6 openings on the transversal direction. I am attaching attach the 2 frames I have done.
Thank you in advance.
I don't know if this is the problem but Revit does not allow pieces less than 1.8/1.6 mm, maybe this is the issue...
2 Posts No Rating |
Thanks for the reply. I have no piece smaller than 1.6mm. I am starting to believe that it is an issue (some form of bug maybe) with the frame generator. I've managed to build the frame in Robot with the frame generator and it works just fine.
I still have the same problem now in February 2015. see picture attached. I have Revit 2014 - template Architecture, units: Inches
How to fix this?? any ideas?
thank you in advance.
Edited on: Mon, Feb 23, 2015 at 9:17:03 PM
This is not a units issue - it is your geometry. You need to take a better look at how you describe it.
Revit Text Generator |
Fri, Feb 4, 2011 at 1:33:36 PM
Hatch Pattern generator |
Thu, Oct 6, 2005 at 1:49:14 AM
Autodesk Labs - Structure Generator |
Wed, Dec 14, 2011 at 5:07:26 AM
Spnish Roof Tile generator |
Thu, Feb 26, 2015 at 3:51:43 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
