Forums >> Revit Building >> Technical Support >> Created pattern based conceptual mass.....no what?
Thu, Mar 8, 2012 at 12:03:25 AM | Created pattern based conceptual mass.....no what?
swegin
Ok, I have created a conceptual mass with a rectangular pattern based curtain panel. I want all of the joints between panels to be very clean so I followed this tutorial on design reform.http://designreform.net/2010/03/revi...-curtain-panelit works great and the surface look soooooooo clean! now..... I have imported the mass into a project file and I want to add mullions and fine tune things, is this even an option?! There are tons of great tutorials about these pattern based conceptual models, but what happens when you need to put your money where your mouth is and develop the project? If anyone has some tips and pointers on taking the conceptual model into a project file and further developing the building it would be greatly appreciated!!!!!
Thu, Mar 8, 2012 at 8:21:35 AM | Created pattern based conceptual mass.....no what?
Kev030981
I used this tutorial to create a twisted torso tower, made up of a frame and panels.  In my case I created two masses - one slightly offset from the other.  I used the outer mass to create a curtain wall of panels using the exact tutorial you linked, and then the other to make a frame that the panels rested upon.  In my case I made a custom frame which was actually hollow curtain panels, but I believe you could apply a simple cutain wall to a mass, split the surface and apply mullions the normal way.
Attached a link to hopefully illustrate what I'm blabbering on about Smile
http://imgur.com/JjkdN
Thu, Mar 8, 2012 at 2:01:13 PM | Created pattern based conceptual mass.....no what?
swegin
Thanks for the tip! The problem I am facing is my form is hard to offset so I do not think I could make a second mass for the framing system. Any other ideas? Is tere any way to use te curtain panel I created from the design reform tutorial in a curtain system?
Thu, Mar 8, 2012 at 2:08:26 PM | Created pattern based conceptual mass.....no what?
Kev030981
Well if it's just the panel - then I guess so, the thing here is going to depend on the shape of the curtain wall.  Are you using the same extruded arc from the tutorial, or is it a more complex mass?  If you can post a picture it may help Smile
Unable to load conceptual mass into project
Fri, Sep 11, 2015 at 1:40:26 PM
Can't get windows to cut through a mass created by dividing surfaces.
Sat, Feb 12, 2011 at 6:52:29 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
Conceptual Mass Project Space Visibility
Fri, Jul 15, 2011 at 1:46:11 PM
conceptual mass problem
Fri, Jan 13, 2012 at 4:02:05 PM
Page generation time: 0.7608
