Forums >> Revit Building >> Technical Support >> Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
Wed, Mar 7, 2012 at 5:12:55 PM | Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
macros976
A wall family may or may not have waterstop built in.  I have a visibility parameter for the waterstop and then I have
an instance parameter for the LF of the waterstop (should be the same as the LF of the wall).
If I turn the visibility parameter off for the waterstop, I don't want the length of waterstop to still show up in the schedule
since it won't be there for that wall.
I tried meddling with some conditioned statements, but couldn't get them to not be circular.
Viz Parameter = Waterstop
Length Parameter = Waterstop LF
I tried this in the Length Parameter box: IF(Waterstop =0,0,Waterstop LF)  - got a circular logic warning, but I don't know
how else to refer back to its value when there is waterstop present.
Wed, Mar 7, 2012 at 5:53:46 PM | Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
TKennedy
4 Stars: 8 Votes
Yes/No parameters are a little funny when it comes to formulas, and you can't tell a parameter to read itself (this is where you are getting the circular reference error). Try this:
Waterstop = Y/N parameter
Waterstop LF 1 = User adjusted length parameter
Waterstop LF 2 = The parameter read by the schedule
Formula for Waterstop LF 2 = if(not(Waterstop), 0' - 0", Waterstop LF 1)
You may be able to make Waterstop LF 2 a calculated value in your schedule, and make the Waterstop LF 1 column hidden.
Also, because Revit seems to have to put a value in Length parameter cells, I don't think you're going to be able to make it display nothing if the value is 0. It's going to display 0' - 0".
Using instance parameter in type parameter formulae
Mon, Aug 12, 2013 at 8:22:38 AM
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:26 PM
Door Scheduling Issue
Fri, Dec 16, 2011 at 1:03:53 PM
INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 2:08:57 PM
Page generation time: 1.0012
