Forums >> Revit Building >> Technical Support >> Problem with parametric mass quadrilateral
Wed, Mar 7, 2012 at 1:36:26 PM | Problem with parametric mass quadrilateral
Kev030981
Hi I'm having problems modelling an uneven quadrilateral (see attached img for details).  I am trying to assign a parameter to control an edge, but run into problems every time. I am admitedly - a little new to conceptual mass moddelling. I'm creating a new conceptual mass, choosing the Metric Generic Model Adaptive template, then attempting to draw the profile and either loft with a double on seaprate reference plane or extrude it - neither is successful.
I've scoured the net for tutorials on this, and none seem to deal with the issue I'm facing - any help will be greatly appreciated.  I can post as many images or files as allowed if I'm not making sense Smile
Many thanks to anyone who can help!
Wed, Mar 7, 2012 at 2:02:07 PM | Problem with parametric mass quadrilateral
Kev030981
oh - Im using Revit Architecture 2012 (sorry) Smile
Thu, Mar 8, 2012 at 9:31:45 AM | Problem with parametric mass quadrilateral
Kev030981
I (think) I've solved it!  Having messed around with so many different settings in revit I went back and looked at the maths of a quadrilateral - and rediscovered its a prtty simple shape.  I went back and drew the profile (on one ref plane), associated a dimension with each of the sides (using a flat edge to begin) and assigned a parameter.  I then extruded and used the offset as a 'width' parameter.  All seems to be working!
How do you make a parametric mass with dimensions and void visibility and volume
Mon, Nov 23, 2015 at 10:03:27 PM
Problem in working with mass
Thu, Mar 18, 2010 at 3:59:29 PM
Problem with a floor slab with Mass
Fri, Apr 25, 2014 at 12:38:46 PM
Mass, radial wall by face, opening(void) problem!
Mon, Nov 11, 2013 at 12:51:10 PM
Parametric mass - Help
Thu, Sep 2, 2010 at 1:32:46 AM
Page generation time: 1.7914
