Forums >> Revit Building >> Technical Support >> Square pyramid
Fri, Dec 16, 2005 at 4:13:38 AM | Square pyramid
Dellboy
Whats the best way of forming a square pyramid shaped component? For example to cap a square brickwork pier with a stone coping.
Fri, Dec 16, 2005 at 12:21:52 PM | RE: Square pyramid
TomDorner
4.5 Stars: 25 Votes
I would create using the blend tool whick lets you define the base and top shapes and blend them together. The Revit help file should have more info. HTH Tom
Mon, Dec 19, 2005 at 5:53:07 AM | RE: Square pyramid
Dellboy
Thanks for the reply Tom.
Mon, Dec 19, 2005 at 12:16:36 PM | RE:
Scott Davis
3.5 Stars: 3 Votes
Quoting Dellboy - 2005-12-19 05:53:07
"Thanks for the reply Tom."
I would grab the pyramid Mass family from the default Revit library (under Masses) and load it into your project.
Post edited on 2005-12-19 12:17:00
Rentable Square Feet Calculation
Wed, Jan 28, 2015 at 9:29:10 AM
Looking for quick easy square footage calculator
Mon, May 19, 2014 at 10:49:34 AM
Square Yards calculations
Mon, Mar 19, 2012 at 3:00:43 PM
Square cut on my roofs?
Thu, May 29, 2008 at 2:32:40 PM
square cut on shed roof
Tue, Apr 10, 2012 at 4:21:54 PM
Page generation time: 1.3884
