18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Curved monolitic stair won't generate in 3d
9 Posts No Rating |
Hi
I'm trying to create a curved monolithic stair, and it't ok in 2d, but it won't generate in 3d.
Is there someting I can change, somekind of thickness or other parameter?
Thanks
It would be easier to troubleshoot this if you uploaded a revit file with just the stair.
**Using Revit Architecture 2009, 2011, and 2012** |
9 Posts No Rating |
I will do that tomorrow, when I get back to work.
Right now, I solved it by creating a Sweep, but a actual stair would be better :-)
9 Posts No Rating |
Here is an example of a stair.
There is a bunch of weird stuff happening on this. I might try to create a new stair and import in the default monolithic stair to override this one so you can start fresh. When I opened it, basically nothing showed in 3D. I noticed the riser thickness was set at 0 as was the tread thickness. If they have no thickness, they won't show. The attached image is what it looks like after I change the thickness to a number greater than 0.
9 Posts No Rating |
@lizard2802
wow - was it that simle... I learn something new every day
can't make monolitic stairs |
Mon, Feb 18, 2013 at 4:01:52 PM
Curved Stair Question |
Mon, May 7, 2007 at 2:10:41 PM
Can“t see entire stair |
Fri, Sep 13, 2013 at 2:16:00 AM
Stair has strange curved underside |
Thu, Aug 31, 2017 at 9:16:25 AM
Curved Stair higher than 4m |
Wed, Jun 3, 2009 at 11:15:02 AM
