Forums >> Revit Building >> Technical Support >> parametric extrusion sketch
Sun, Mar 4, 2012 at 11:46:06 PM | parametric extrusion sketch
I12b3
To create a timber frame family, I need to precisely notch the timbers.To control the dimensions with parameters, length, width, depth, there is no problem.And then flexing the dimensions works just fine.
Now when I want to make notches in the extrude profile and control the sketchwith parameters, I get a "constraints are not satisfied" message on attempting to flexthe parameters. In this case setting  'a = 27' in the parameters properties dialog box.And the only option offered is to remove the constraints. What should I be doing?
Revit Rocks
Mon, Mar 5, 2012 at 8:38:56 AM | parametric extrusion sketch
cketros
try this one
Mon, Mar 5, 2012 at 12:16:27 PM | parametric extrusion sketch
I12b3
OK I understand that in order to control sketching through parameters
you have to construct your drawings with reference planes.
It worked for the first cut, but the method gets stuck on the second cut.
See new attachments.
Also I would like to know how to anchor the starting plane, and have
the secondary planes move in relation to that one. Being able to set
sketch lines and reference lines to a thinner gauge would be nice too.
Revit Rocks
Mon, Mar 5, 2012 at 12:23:35 PM | parametric extrusion sketch
I12b3
Hi cketros
Any way you could pack your example in RAC2011 readable format,
or spell out the gist of the strategy you are suggesting?
Sorry. Don't have access to RAC2012 where I am.
Revit Rocks
Mon, Mar 5, 2012 at 1:52:26 PM | parametric extrusion sketch
TKennedy
4 Stars: 8 Votes
See attached
Wed, Mar 7, 2012 at 12:48:06 AM | parametric extrusion sketch
I12b3
OK I got it thank you.
The key to the problem is to use reference planes and lines unsparingly,
and lock everything down like crazy. It's now working fine.
Thank you very much for taking the trouble.
Revit Rocks
Wed, Mar 7, 2012 at 9:23:24 AM | parametric extrusion sketch
TKennedy
4 Stars: 8 Votes
Absolutely. With very few exceptions, you don't want to flex any model elements (extrusions, etc.) directly. Build a skeleton out of ref planes/lines, and make that parametric. Then tie your model elements to that.
Wed, Mar 7, 2012 at 9:48:33 AM | parametric extrusion sketch
I12b3
Revit Rocks
How to edit a sketch of Extrusion?
Thu, Aug 1, 2013 at 10:38:11 AM
curvy sketch extrusion [ 1 2 ]
Fri, May 6, 2011 at 8:23:47 PM
16
Sketch a path greyed out...can't alter sweep path
Mon, Jul 26, 2010 at 4:45:05 PM
Sketch up
Thu, Mar 15, 2007 at 6:46:50 PM
FATAL ERROR WHILE IN SKETCH MODE
Mon, Aug 12, 2013 at 1:58:25 AM
Page generation time: 3.1080
