Forums >> Revit Building >> Technical Support >> Delete!
Fri, Dec 16, 2005 at 4:07:05 AM | Delete!
nandini
hi, i wanted to know if there is a way of deleting imported drawings that exist in a project and are seen only in V.G and in no other view. i do not want to have things that i dont use . but dont know how to remove them
Fri, Dec 16, 2005 at 7:55:44 AM | RE: Delete!
JAIMERIOSJR
Good day. There is a Purge Command in file>Purge then select the unwanted items.
Fri, Dec 16, 2005 at 12:25:43 PM | RE: Delete!
TomDorner
4.5 Stars: 25 Votes
Be careful about "importing" AutoCAD drawings. I find it best to only "link" them so the can be easily removed and add very little overhead to the Revit project. Check the "link only" button when importing. Also be aware the the "manage links" on the file menu is available when ACAD files are linked in. This is kind of like an xref manager that allows you to delete, reload and repath your linked files. HTH Tom
How to delete Title Blocks
Thu, Feb 28, 2013 at 9:34:03 AM
why can't i delete lines in family edit mode?
Mon, Jan 1, 2018 at 6:26:55 PM
Can't delete materials!
Thu, Jul 16, 2009 at 3:35:08 PM
How to delete rebar?
Tue, May 26, 2020 at 5:25:50 AM
Delete View Types
Thu, Mar 23, 2017 at 10:43:22 AM
Page generation time: 0.2237
