Forums >> General Discussion >> Revit Project Management >> Floor plan, Elevations Etc to Drafting view in Revit 2012
Fri, Mar 2, 2012 at 9:16:32 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
4220stiv
Help??
How can i get Floor plan etc to drafting view whitout export to Auto cad and back to revit 2012??
Or freeze a Floor plan will be okay.
I Hope you can help.
Fri, Mar 2, 2012 at 9:32:26 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Why are you trying to put a floor plan to a drafting view?
Fri, Mar 2, 2012 at 9:45:57 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
4220stiv
so the plan is indepentet from the model, so i can change the plan but stil have the old one on the sheet.
Fri, Mar 2, 2012 at 9:48:06 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
I think you want to use design options.  Then you can have two different model floor plans.
Fri, Mar 2, 2012 at 9:51:20 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I agree with WWHub, Design options would be the way to go
Fri, Mar 2, 2012 at 9:54:56 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
4220stiv
No its not that.  I´m a student in Denmark, We work en phases, so i want to work further whit the model. But stil have the first phases on the sheet, and then work further whit the next phase.
Fri, Mar 2, 2012 at 10:22:59 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
If these are really phases like exiting / new, then just use phases.  Otherwise, design options or just using a new workset might do what you want.  You do know that you can have multiple views - correct?  So PHASE ! is on a sheet, duplicate the phase I plan - call it phase II and add your components using worksets, phases or DO as appropriate.
Fri, Mar 2, 2012 at 10:48:44 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
4220stiv
No its not that either.
I dont understand why i can take a planview or a section to drafting view and then it is indepentet from revit model.
I need to do it like this because it is a school situation
My english is not very good so i can not really define med as weel, but hope you understand
Fri, Mar 2, 2012 at 11:07:04 AM | Floor plan, Elevations Etc to Drafting view in Revit 2012
OK - If you don't want to use the available tools in Revit, then to answer your orginal question, you have two options:
  1. Trace all of your linework in the view using lines then turn off all model elements.
  2. Use the freeze view option available in the add-ins.  Which exports the plan to CAD and imports it as a drafting view.  NOTE:  All of the dimensions are now just linework.  To change, you have to re-draft.
Fri, Mar 2, 2012 at 6:38:06 PM | Floor plan, Elevations Etc to Drafting view in Revit 2012
rod23
5 Stars: 4 Votes
The request to "freeze" a view is something I have wanted, but is not an option in Revit.  Is the problem that you've got your view looking the way you want, but as you work in another view, things pop up in the first view?  That's revit, everything is part of the model.  If you are working in "Phases", which is based on TIME, then you should create phases as per the WIKI help.  I wrote the first paragraph BTW.  If you are proposing multiple variations of the model, then use design options, or just make copies of your project.  Whatever you do, do NOT try to use Revit in a way it is not designed to do, e.g. do not use phases just to get your graphics looking right.
http://www.turbosquid.com/Search/Artists/Revitaoist
3 elevations 1 floor plan
Tue, May 15, 2007 at 7:13:01 AM
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:14 PM
DRAFTING VIEWS ON MORE THAN ONE SHEET (REVIT 2012)
Wed, May 23, 2012 at 8:42:46 AM
IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN?
Tue, Jan 25, 2011 at 1:25:12 PM
Create sub menu in Project Browser Floor Plan Views
Tue, Jan 1, 2013 at 8:34:40 PM
Page generation time: 2.1053
