Forums >> Revit Building >> Technical Support >> multiple project north
Thu, Mar 1, 2012 at 3:53:04 PM | multiple project north
sgray05
I am working on a project that has a number of different angles. Is there a way to create multiple project norths such that I can toggle between them depending on what area of the building I am working on?
Fri, Mar 2, 2012 at 2:03:05 AM | multiple project north
gebber
gebber Avatar
5 Stars: 4 Votes
It won't be realistic if that would be possible.
Jou can rotate the "view port" though.
Fri, Mar 2, 2012 at 6:47:14 AM | multiple project north
Gebber is saying that you should create multiple views with each one rotated according to your needs.  This is not rotating project north.
Multiple Project North
Tue, Apr 12, 2011 at 10:12:46 AM
Multiple project north[s]
Fri, Apr 15, 2016 at 3:15:11 PM
11
rotate PROJECT north (not true north)
Wed, Jun 10, 2009 at 9:11:40 AM
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
Spot Coordinate - True north vs project north
Tue, Oct 22, 2013 at 4:42:05 PM
Page generation time: 0.5670
