Forums >> Revit Building >> Technical Support >> Exported model patterns shift in DWG
Thu, Mar 1, 2012 at 1:44:41 PM | Exported model patterns shift in DWG
JFloor
Working with sloping floors with a score pattern.  Everything looks great in Revit, but when exported to DWG (as the client requires), the resulting hatches come through totally out of whack from one sloping plane to another.  See comparison in uploaded jpg.  Have tried the align tool and exporting to DXF, but the same result.  Floors must be built with the slope to drain for coordinating with other consultants.  Have resorted to 2d workaround (filled regions), but not exactly satisfactory.  Ideas?
Sheets exported to DWG
Tue, Jan 15, 2008 at 5:42:15 PM
Is exporting model patterns from a 3D view possible ?
Wed, Nov 24, 2010 at 1:59:07 PM
Revit Not Cutting Through Imported .dwg 3D Model
Mon, Jan 19, 2015 at 2:05:11 PM
Revit 2012 Export To DWG. Titleblock exported as Block.
Wed, Jun 12, 2013 at 6:16:23 PM
Some problems with the export from rvt to dwg
Thu, Jan 14, 2010 at 3:10:42 AM
Page generation time: 1.6776
